上个星期,影音中国“大师问答Ask the Guru! ”正式上线之后,我们陆续收到了不少读者的问题,内容包括器材的购买和摆放、全景声影院的构建以及一些相关的音视频技术问题等等。有些问题非常具有代表性,而且相关专家和行业人员的回复也详细专业,我们特地挑选了其中四个问题给大家作参考。
问题一
我能够在同一系统中使用两个不同的低音炮吗?
Gerry Lemay(HAA家庭声学联盟创始人与主席 ):
This is a question that always seems to come up in classes... and for good reason. Its much easier to buy an additional sub than to buy two new subs. The answer is not always easy. For example it depends on just how different the subs are.
这个问题经常在THX-HAA的课堂上出现,毕竟买一个附加的低音炮比买两个新的更容易。但是答案却并不总是那么简单。比如它取决于两个低音炮有多不一样。
For obvious sub differences like power and driver size the big problem is that the sub layouts used by the HAA depend on a true balancing of capability. Subs need to be sound balanced for the best results. A sub that is louder than another will defeat the desired push-pull nature of the sub interaction. Its also very difficult to match the sound level of two disparate subwoofers. Bottom line is that you are making your calibration much more difficult. Difficulty in calibration often means no true calibration is completed.
低音炮之间明显的不同,诸如在能量和驱动器的尺寸上,但最大的问题是HAA所推荐的低音炮布局实际上是建立在真实平衡的低频能量感之上。为了实现最好的声音结果,低音炮的声音需要听起来和谐。一只低音炮比另一只大声,将会打破低音炮相互作用时的平衡状态。而想要匹配两只不同低音炮的声压是非常困难的。结果就是你的调校也更加困难,通常也意味着你将很难完成真正意义上的调校。
In the case of subwoofer mismatch the great results that the theory predicts may actually not occur. My advice is to use the same identical subs in sets of two or four. You'll end up with a great sonic result and be able to do it in a reasonable amount of time.
当然低音炮搭配不当的或许并没有出现理论方面的问题。但我的建议还是使用两只或四只相同的低音炮来搭配。这样你能在不会太长的时间内得到最好的声音效果。
问题二
究竟我需要多大的低音炮?
The answer to this question is simple, how much money do you have? Sorry, I don't mean to be crass. The truth is that the real question should be "How Big Should My Two Subwoofers Be?". You might have seen that coming. Proper subwoofer implementation is best done with two or four subs. The real issue is that smooth bass means that much of the room gain is lost. Room gain meaning extra energy that comes from peaking standing waves in the room. So the boost your room gives your sub output also badly distorts the signal. Standard subwoofer calibration means placing the sub(s) to reduce standing wave distortion and following up with equalization. All these adjustments rob the sub of gain.
这个问题的答案很简单,你有多少预算?这是开玩笑的说,而且真正的问题应该是“我的两个低音炮应该多大?”合理的低音炮摆放应该是两个或四个。想要获得平滑的低频就意味着丢失房间的大部分增益。房间增益是指房间驻波达到顶峰时产生的额外能量,它施加在低音炮上的推力也将令低频信号严重失真。标准的低音炮调校意味着合理放置低音炮并伴随增益均衡器的调整来减少驻波的失真。而所有这些调整又将损失低音炮的增益。
To compensate for the lost gain, you need capability; power and woofer size. I've definitely had to back off on bass smoothing more than once as the mild mannered subwoofer I was calibrating began running out of gas. And that's the long and the short of it; buy the most capable subs you can. That's the best way to make sure you have the powerful bass you want that is also musical and beautifully integrated into the system.
为了补偿损失的增益,你需要低音炮具备更大的能量、更强的功放推力和更大的低音单元尺寸。当我正在调校的低音炮开始失真或是停止工作时,我不止一次为了低音更加平顺而在增益上做出妥协。毕竟这已经是这台低音炮的极限了。所以尽可能买你能买到的最强的低音炮吧。这是确保你想要的低频同时兼备能量型和音乐性,并能漂亮地和系统融为一体的最好方式。
问题三
如果沙发靠墙放,室内空间不够,能不能建立5.1.4杜比全景声系统?
薛磊(上海尊宝音响有限公司产品推广总监):
“沙发靠墙”与“室内空间不够”是2个概念!
如果确实空间较小(20平方以内),而且沙发只能靠墙,那么推荐5.1.2。
通常对于2排以上座位,家庭全景声推荐.4声道,以便每个座位都能获得很好的三维效果。而空间较小,同时只有一排沙发靠墙,那么顶部声道用.2已经能够满足需求。
当然,如果空间较大的情况下,沙发靠墙,也有可能用到7.2.2的全景声系统;
顺便说一下,5.1系统中的环绕通常指侧环绕,THX要求沙发靠墙的情况下环绕最好离开后墙60CM才能获得最佳效果。然而基于我们客厅的现状,两侧很难摆放环绕,建议用吸顶式环绕效果更佳!
李广(者尼私人影院首席技术官):
如果空间不够,最简易的杜比全景声实现方式就是购买杜比全景声专用扬声器,这种音箱会向天花板辐射声波,通过声反射来实现顶置环绕的效果。如果一定要在天花板上安装扬声器,在空间有限的情况下,我的建议是安装一对扬声器,功率可以适当大一些,距离后墙约1-1.5米。多余的预算,如果可以,增加一只低音炮,增加一只低音炮带来的效果提升,会比增加一对顶置环绕来的明显。
问题四
卡拉OK音箱接上卡拉OK功放后有“滋滋”声是什么原因?怎么解决?
如果没有接麦克风,只是功放连接音箱就出现这种问题,有以下可能性:
1、电源:周边设备干扰或设备本身电源;
2、设备:功放信噪比差,音箱灵敏度高;
3、连接:连接件之间的问题,例如插头、音箱线等;
解决方案:
1、 先排查周边是否有大型设备在电源上的干扰,例如空调、冰箱等对卡拉OK这路电源有干扰信号!可以先关闭这些设备测试。设备本身如果是3个头电源线,带有接地这路,可能也会受到其他干扰,可测试不带接地的2路电源线尝试。
2、功放本身信噪比高,导致音箱出现本地噪音;也有的采用灵敏度较高的音箱,音源或功放的噪音被播放出来!遇到这类情况,属于先天不足,要么忍,要么扔!
3、很多比较差的连接件(可能没插好,可能本身氧化等问题)也会让噪音暴露出来!排除以上2个问题后,需要重新检查这些连接件!
李广(者尼私人影院首席技术官):
一般来说,这种噪音不是喇叭引起的。我会首先考虑检查一下功放,功放的质量不佳,或者功放接地不良比较容易触发类似问题。如果功放检查没问题,那就接着检查卡拉OK效果器和无线麦克风接收机的设置,这两类产品参数设置不对,也容易将噪音引入功放,然后功放放大后,引发噪音问题。采用排除法可以发现问题的源头,不过最好是找专业人士来解决类似问题。
