本期的“大师问答Ask the Guru! ”栏目总共收集了六个问题,从某个层面来说,概括了我们这个栏目的特色之一:理论联系实际。不管你是在构建家庭影院时碰到难题,还是对于某些“江湖传闻”持怀疑态度,都可以留言让我们帮忙解决,来者不拒哦。
如果想加强房间的低音效果,更换一只更大尺寸的低音炮和增加低音炮的数量,哪种方法比较合适?
Gerry Lemay(HAA家庭声学联盟创始人与主席 ):
Both ideas will result in greater bass capability, but there are two other factors to consider. First, a larger sub will typically have better low frequency extension. There are several very large subs being manufactured these days which have powerful bass response down to 20 Hz and below. It’s hard not to choose such a sub over several smaller subs when you want high impact and full bass response. The second issue is response smoothness and seat-to-seat consistency. The use of two or four subs placed in the proper positions of the room makes the bass better integrated and much more consistent across a wide area of the room. This is my preference since I believe most theaters have more than one seat and I also enjoy listening to high end music on my system. The excellent bass integration and smoothness multiple subs creates makes this a very pleasurable experience.
两种方法都能获得更好的低频能量,但是有两个其它因素需要考虑。首先,一个更大的低音炮将会有更好的低频延伸。目前有好几个非常大的低音炮正在研发制作中,它们有着20Hz及以下的强有力低频响应。当你想要获得更高的冲击力和更饱满的低频响应时,很难不去选择这样的低音炮而是选择几个更小的。但是我们还要考虑的是低频响应的平滑性和座位间的一致性。选择在房间的恰当位置放置两个或四个低音炮,可以使低频更加连贯,在房间的大部分区域也能显得更为一致。这是我的偏好,因为我相信大部分影院都不只一个座位,我也喜欢用我的系统听高保真音乐。多个低音炮创造的杰出的低频整合性和平滑性,让我能获得更好的体验。
HAA家庭声学联盟创始人与主席 Gerry Lemay先生
是不是什么房间都可以安装天花音箱?能不能只用天花音箱做一个多声道音箱系统?如果想安装需要注意什么问题?
This question depends on many factors. I assume you mean to do home theater? In that case, ceiling speakers can be limiting. The front speakers sound best when their sound is presented horizontally and from a height close to your ear level. While there are ceiling speakers designed to point more forward and horizontally, they can create a front sound stage which is too high and not as precise. Interestingly, if you choose ceiling speakers, it’s important to allow reflections from these speakers to bounce off of the right and left side walls. This creates the illusion of pulling the soundstage down appearing to be better aligned with the screen. In the case of surround speakers, a horizontal presentation of the sound field is also best. One can again try to use nearby walls to reflect the sound toward the listeners. To do this the ceiling surround must be close to the wall to create the proper reflections. If you are planning an Atmos system, you may be disappointed to know that it’s not a good design to have both your side surround speakers and top speakers in the ceiling. The spatial effect will not be nearly as good.
这个问题取决于很多因素。我假设你是想建造一个家庭影院?在这种情况下,天花板的音箱是受限制的。当前置音箱的声音是从接近你耳朵水平面的高度水平传来的时候,听起来是最好的。但是有一些吸顶音箱是被设计成更向前方与更加水平的位置,这样会产生一个太高而且不精确的前置声场。有趣的是,如果你选择天花音箱,让这些音箱的反射从左右两边的墙壁反弹回来非常重要。这样能产生将声场往下拉伸的幻觉,好像可以和屏幕更好地匹配。对于环绕的音箱而言,声场的水平呈现也是最好的。一个可以再次尝试的方法是用旁边的墙面去反射朝向听众的声音。这需要天花板的环绕音箱和墙面非常接近,才能产生合适的反射。如果你计划要建一个全景声系统,可能会失望地得知将侧环绕音箱和顶部音箱都安装在天花板不是一个好设计。空间效果将不会那么好。
对于半开放、没有声学处理的客厅环境来说,有什么方法可以改善声音效果?
A semi-open space can be quite challenging. There are several problems; 1) sound power is lost through open spaces limiting reference sound level, 2) As you fear, there can be excessive reverberation reducing focus and clarity, 3) Its more difficult for an acoustician to predict the sonic behavior for best seating and subwoofer placement, and other issues. You question seems to focus on the second of the issues I listed. For this problem there are only two solutions. The best solution is to add acoustical treatment to reduce the reverberation of the room. If that is not possible, the only choice is to reduce the number of listening seats and move these closer to the speakers, or the speakers closer to the listeners. The acoustical principle is that the reverberation is too loud compared to the direct sound level from the speakers. This is how focus and clarity are reduced. Without treatment, the only way to increase the relative level of the direct sound is by listening closer to the speakers. Turning the volume up is not a solution since the increased direct sound level will still create an even louder reverberant sound level.
一个半开放的空间非常具有挑战性。将会有几个难题:1、声音的力量将会在参考级声压范围下向开放空间丢失;2、就如你所害怕的,将会产生过多的混响导致声音的聚焦和清晰度减少;3、对一个声学家来讲,更困难的是去预测最好座位的声学状况和低音炮的放置,以及其它问题。你的难题似乎是聚焦在我所列举的第二点。对于这个难题,有两个解决方法。最好的解决方法是增加声学处理,减少房间的混响。如果这点不可能实现,唯一的选择是去减少听众的座位数量,并把座位放置得离音箱更近,或是让音箱离座位更近。声学处理的原则是跟音箱直达声的声压相比,混响太大。这是聚焦和清晰度减少的原因。没有声学处理,唯一增加直达声相对声压的方法便是离音箱更近。将音量调大不算是解决办法,因为增强的直达声声压仍然将产生一个更大的混响声压。
为什么售价不菲的高端耳机基本上都是高阻抗、低灵敏度设计?
薛磊(影音大师产品推广总监):
这个问题其实早有定论,高端耳机确实大多都是采用高阻抗、低灵敏度设计,当然也有例外,例如FOCAL劲浪的旗舰级纯铍乌托邦耳机的阻抗虽然只有80欧姆,灵敏度却达到104分贝,高灵敏度地设计使其更容易被推动。
高阻抗/低灵敏度的设计的高端耳机基本都采用大尺寸动圈式设计,因而本身的材质决定了无法达到高灵敏度(音圈+振膜相对较重);同时,因为高阻抗的设计可以更好地过滤掉信号中的杂讯,因此达到低阻抗,动圈式的材质就更重了,低灵敏度也就成了必然。如果驱动电压足够, 高阻抗反而会带来更高的音质表现。所以,如果是高阻抗、高灵敏度那就更好了,但受到振膜材质的影响而无法实现,FOCAL乌托邦耳机的例外是因为铍高音材质足够得轻盈。
当然,这也是仁者见仁,拜亚动力的DT770、DT880、DT990这3款耳机,厂家分别提供了32欧姆、250欧姆、600欧姆三个版本,消费者可以根据需要进行选择。
影音大师产品推广总监 薛磊先生
有人说,在视听领域,“新手玩的是器材,高手玩的是房间”,这种说法有道理吗?
薛磊(影音大师产品推广总监):
有一定的道理!
或许很多影音发烧友一辈子都在玩器材,从音箱、功放、音源等设备一直到电源、线材类辅件,他们对器材的熟知度非常资深;但是,所有的器材演示都是在房间中完成,因此器材+房间+摆位调试才是一整套。
而对于新手来说,最直观和容易入手的一定是器材!到了一定的境界,或许某些器材不能符合自己的需求了,那么就会更换设备,一直在器材中折腾。直到某一天,发现原来一切的问题在于聆听环境的时候,那时候就开始研究房间对声音的影响,研究室内声学的重要性!
所以,从这个角度来讲,确实存在一定的道理!当然,无论新手还是老手,在视听领域想要成为高手,只最求器材或房间都是片面的。必须综合考虑器材的搭配、摆位调试以及聆听环境的室内声学,这才是高手所为。
耳机“煲机”是玄学吗?
薛磊(影音大师产品推广总监):
说到煲机,对于音频发烧友来讲,这就是家常便饭,耳机同样也是,和玄学扯不上关系。耳机和音箱类似,扬声器振膜的折环刚出厂时顺性不够,声音偏紧,听感偏硬,无法充分发挥其最大的潜力。如同乐器一般,弹过吉他、拉过提琴的朋友都知道,刚换上的新琴弦声音不是最好,而是要经过一段时间的使用之后,声音才会达到最佳状态。耳机也是同理,经过“煲机”,各个频段的“刺激老化”之后,硬度逐渐下降,振幅达到一个接近理想的状态时,就可以获得好音质了。建议大家在煲机时,除了用白色噪音和粉红色噪音之外,也要用自己喜欢的音乐类型去煲机,这样在大家在欣赏喜欢的歌曲类型时可以聆听到更好的音质,让大家越来越喜欢自己的耳机和歌曲。
